Best Way to Set Up A PS2 To A HDTV Set?
Discussion in 'Playstation Forums' started by Jakks, Jan 11, 2008.
  1. Jakks
    Jakks
    Dec 12, 2006
    551
    +55
    I'm thinking about connecting up my PStwo to my HDTV (LG 26LC2R ) and was wondering what the best way to do this is? I'm not sure what type of cables are/where available for the PStwo as I used to use the standard one when I had a CRT TV, my only draw back is that the component sockets are currently been used for my 360. Any views on what to do?
  2. 6950rpm
    6950rpm
    May 26, 2006
    149
    +10
    Highest quality video you'll get from a PS2 will be from component second to that will be RGB Scart.
  3. Jakks
    Jakks
    Dec 12, 2006
    551
    +55
    Cheers, might end up getting VGA cable for the 360 then I'll have the component sockets free for the ps2
  4. philylit
    philylit
    Jul 10, 2006
    25
    3
    Hey 6950rpm, I see you have the KDL-40w2000u , how well is the ps2 displayed on it? Have the chance to pick one of these up for around 880 quid but sd (wii + ps2) picture quality is quite important to me b4 I bite.
    The jaggies i get on my 50" sony RP 3LCD when using my wii (component) and ps2 (RGB scart) do my nut in!
  5. 6950rpm
    6950rpm
    May 26, 2006
    149
    +10
    Well hooking the PS2 up to the TV directly via component and then turning on progressive if the game supports it gives an exceptional picture. Better than running the same game on the PS3 I find.
