Best way to scale down HD samples for watching on DVD ?
Discussion in 'General TV Discussions Forum' started by RecordablDVDfan, May 7, 2005.
  1. RecordablDVDfan
    RecordablDVDfan
    Aug 13, 2003
    2,902
    68
    +49
    I am using a great prog called H.264 Encoder for other video files, many many settings, is this a good prog for scaling HD samples from the 3 HD channels or is there a better one I should know about ? What settings should I use in any case for the best results ?
  2. Rob.Screene
    Rob.Screene
    Sep 29, 2001
    1,314
    Berks, England
    +140
    Domestic DVD players won't play H.264 encodes, they'll only generally do standard MPEG2.
    I'd probably use AVIsynth (Lancoz resize down), DGindex and TMPGenc/TMPG Author to do a good encode with film-mode 3-2 pulldown removal. But then again I like to do things the hard way to knwo they are right. Pulldown removal might need the TMPGenc 3-2 pulldown feature thatis slow but works well for really poorly flagged material.
    Or wait 6 months till H.264/WMV players are available!
    regards,
    Rob.
  3. Leerock
    Leerock
    Dec 26, 2004
    273
    19
