best way to (run in speakers) eg 2 days continuos loud soft etc
Discussion in 'Home Cinema Speakers' started by mick23, Aug 4, 2002.
  1. mick23
    mick23
    Mar 20, 2002
    801
    uk
    my bw cdm1nts still seem a bit (harsh in treble and midrange seems to be a bit lacking) dealer suggested i give them a good run in , should i run them non-stop and for how long, i have seen anything from 15hours to 60hours non stop, (do not want my amp to go into meltdown) advice please
  2. GJC
    GJC
    Mar 1, 2002
    2,142
    London
    +69
    I have B&W 603s2 - They took approx - 30 hrs to run in. The treble was very harsh and the midrange flat. Now the treble & midrange integrate much better. The bass can be a bit unruly but plugging the ports help.
    I ran them loud and soft it varied for me.
    However I am sure you can reverse the polarity and and run them so the sound waves cancel each other out.....off the top of my head you swop the red and black terminal at the speaker end of one speaker and then place it in front of the other speaker. I believe you can crank them without hearing much audio yet the cones still react as normal.
    Please make sure you dont try this un=til someone else can varify this for me as I am not 100% on this.
    Regards,
    GJC
  3. mjn
    mjn
    May 24, 2001
    23,545
    Herts, England
    +11,951
    yep, you're right, with the speakers facing each other, reverse the polarity of one speaker, and the waves should cancel each other out.
    Running in takes around 30 hours on the NT series, or so it states on their web site.
  4. Charlie Whitehouse
    Charlie Whitehouse
    Probably best to select a MONO source to improve the cancellation. Something like a tuner, rather than wear your CD player out....
  5. mick23
    mick23
    Mar 20, 2002
    801
    uk
    do i run in say 30hrs non stop or in stages thank you
  6. Guest
    Don't forget (very important): after you've run your speakers in, you will need to ensure all your existing cabling is properly run in too:
    http://www.audioexcellenceaz.com/audiodharmacablecooker.htm
    Fortunately, the Pro version will also 'break in' power cables. Although, funnily enough, I haven't heard of many 'pros' using this kind of thing (must be a big insider secret or summat ?).
    Also, note: "it does not have an S-video connector on it, but Radio Shack or another popular commercial supplier might have an RCA-to-S video adaptor that could be used to break in that type of cable." So that's handy. Oh, and you can daisy chain cables to burn them in simultaneously (using couplers). Fantastic !
    [​IMG]
    Mike.
    cheek <- tongue
  7. warrj
    warrj
    Yeah and you should do a sonic break-in of your furniture too. This simply involves playing a representative selection of music over a 7 day period in order to align the molecules in your furniture with the sound pressure waves generated by your hi-fi. Since these waves will change anytime you either a) buy a new component or b) get into a new style of music its important to repeat this process when on a regular basis.
    Regards,
    Jules.
  8. Guest
    Jules,
    Do you not do sarcasm ?
    Mike.
  9. warrj
    warrj
    Mike,
    Yeah, I realised that you weren't seriously endorsing the idea of burning in cables. I was just trying to add another ironic comment to the thread.
    Jules.
  10. Guest
    Phew, I thought that you thought that I was bonkersmadcuckoo back there....
  11. warrj
    warrj
    Nope. Although clearly enough people are in order to make cable burn-in machines commercially viable. I'm guessing that they've never been subjected to double-blind trials.
    Jules.
  12. Guest
    Can I just add here that although there may be an extremely small change achieved by 'running in' some cables (heck, I've got to admit that it's not impossible) as soon as that gizmo mentioned running in power cables I fled for my life. That and the $749 pricetag. Now where did I put my 'nuts' gif ? Aah, there it is:
    [​IMG]
    Mike.
  13. mick23
    mick23
    Mar 20, 2002
    801
    uk
    went to hifi dealer to get some bi wire cables made up they recomended dnm reson2 cable, this dealers sells very high end gear, he mentioned they do (burn in cables they make up for 24 hours on some £700 gadget) i got cable because i wanted to biwire my front speakers as suggested by three hifi shops i contacted and b&w tech support , shop will post cable to me when ready just hope i can tell if any difference re single run or biwire thanks all
  14. Spanglemaker
    Spanglemaker
    Jul 4, 2002
    76
    +10
    I would also suggest that you also invest in a new keyboard - one that has working shift & full stop keys. ;-)
  15. Lowrider
    Lowrider
    I did notice big improvements after some equipment had burn in, particularly the IC cables and the DVD player...
    But I just used them normally until they where fine, no special tricks... you need patience...
    If after about a month you still have problems, get other speakers... :devil:
