Best way to package subwoofer for delivery
Discussion in 'Home Cinema Speakers' started by devag, Jan 23, 2018.
  1. devag
    devag
    May 21, 2016
    47
    11
    UK
    I need to return a sub woofer back to where i bought it from but dont have the orginal box unfrotauntley. Any recommendations on best how to pack this and where best to get the packaging materials online? other than a cardboard box and alot of bubble wrap with alot of fragile tape on the box i cant think of anything else?
    thanks
  2. DodgeTheViper
    DodgeTheViper
    Oct 23, 2001
    19,665
    Inbetween Upgrades !
    +8,085
    Bubble wrap is probably not the best thing to use for the packaging. Something like a styrene or polyethylene foam type product would be better suited.
  3. Dolus
    Dolus
    Apr 26, 2005
    533
    46
    Gosport
    +147
    If you are returning to the manufacturer ask them for the packaging.
