Best way to mod fully wired Scart?
Discussion in 'Plasma TVs Forum' started by sabujo, Sep 19, 2004.
  1. sabujo
    sabujo
    I'm looking forward to snip a couple of pins on my fully wired flat scart cable. Can anyone tell me what pins to get rid off in order to end up with a one way rgb cable with sound?
    Thanks in advance
  2. pjclark1
    pjclark1
    Jul 19, 2004
    4,463
    Thailand
    +271
    pin 19 from one end, pin 20 from the other (this removes composite video loop back)
  3. sabujo
    sabujo
    Done! Any more? Still holding the pliers. BTW wich end shall I mark DVD and TV?
  4. Ekko Star
    Ekko Star
    Mar 18, 2002
    6,619
    London
    +468
    I also snip pins 1 & 3 at the display end of the scart. This way I get 100% no cross talk from the output Audio. Quite important if you're using a Viera plugged into AV2 & AV4. ;)
  5. sabujo
    sabujo
    Done! How about s-vídeo? shouldn't I get rid of it also?
