best way to link PS2 to TV
Discussion in 'Playstation Forums' started by Ashy, Feb 5, 2003.
  1. Ashy
    Ashy
    Jan 3, 2003
    374
    +14
    whats the best lead to use for connecting a PS2 to an FQ75?
    Im currently using the normal one you get with the console and am wondering if you can improve picture etc?
    Im using an optical lead to connect it to my DAV to get the sound through those speakers
  2. graham.myers
    graham.myers
    Get an RGB capable PS2 to Scart lead and plug it onto the (usually) blue scart on the back of the telly
  3. digitaldave
    digitaldave
    Jan 7, 2003
    261
    St Evenage
    +12
    Ashy,
    I agree with Graham, get an RGB capable SCARt lead. The official Sony lead is quite expensive, but Game (and HMV I think) have one called the 'Blaze Ultimate SCART' or something like that. It's around £15, and it has a switch - in one position, it outputs composite (the same as what you're using at the moment I think) so you can watch DVD's without the green screen, and in the other position it outputs RGB for top quality game performance. I got one myself recently, and it's a top piece of kit :cool:.
    As for connecting to your TV, I don't know anything about that model, but check your user manual, that should be able to confirm which SCART socket is RGB capable.
    Hope this helps!
    Regards,
    Dave.
  4. Ashy
    Ashy
    Jan 3, 2003
    374
    +14
    i wont be using the ps2 for dvds at all mate, so it will solely be for games. do companies like ixos etc do them? or do you have to get either sony official ones or ones that games shops have?
  5. graham.myers
    graham.myers
    I've not heard of IXOS et al doing them.
    The ones from Game et al are fine. I've got a PS2 > component and its OK so they RGB ones should be fine.
    The blaze and other similar makes are a fraction of the sony price but are not inferior as far as I can tell.
  6. Ashy
    Ashy
    Jan 3, 2003
    374
    +14
    thanks mate, are they worth bothering with, or is the difference in pic quality minimal?
  7. graham.myers
    graham.myers
    You will notice the difference - good buy at £9-£15
  8. lentini
    lentini
    Jun 28, 2002
    3,551
    Dog Eater
    +455
    IXOS do indeed do them.
  9. Ashy
    Ashy
    Jan 3, 2003
    374
    +14
    aha, think ill have a search around for that then, cheers mate.
    that sig is fantastic by the way :laugh:
  10. CIMPSA
    CIMPSA
    Mar 17, 2002
    65
    Las Palmas, Gran Canaria
    Ashy, have a look at www.hifistore.co.uk, I have one in order right now, I think they are just waiting for stock. It really looks good, and it is something like 32.95 inc delivery.
  11. graham.myers
    graham.myers
    :nono:
    As requested by spectre and the mods these forums is for AV discussions
    if you want to talk football go to a football site and vent your spleens there and dont waste the bandwith of this site
  12. graham.myers
    graham.myers
    is that football talk again:D :D
    seriously glad we answered your original question
  13. Ashy
    Ashy
    Jan 3, 2003
    374
    +14
    he he :)
    think i may as well get one, spent enough on leads as it is, no point having the ps2 feeling all left out :p
  14. NeilMcRae
    NeilMcRae
    Sep 2, 2002
    1,187
    41
    London
    +6
    I've removed the football posts as it ruined a good thread. Please stay on topic.
    Neil.
  15. Rookies
    Rookies
    Jan 4, 2003
    5,496
    +487
    Ashy
    Did you find a good lead for your PS2 then at what price and where from if you have
  16. Ashy
    Ashy
    Jan 3, 2003
    374
    +14
    ive emailed a few places mate, once ive got some replies ill post on here what they said.
    i emailed QED as ive got all there leads for my setup, so im seeing if they do one :)
  17. Rookies
    Rookies
    Jan 4, 2003
    5,496
    +487
    Ok mate, keep us posted as I am looking for a one aswell
