Best way to isolate a sub?
Discussion in 'Subwoofers' started by belgrade, Dec 28, 2004.
  1. belgrade
    belgrade
    Mar 4, 2004
    137
    16
    newcastle
    Hi all,
    As the title suggests, just want to find out the best way to isolate a downward firing sub (bk xls200) from laminate flooring.
    I was thinking of popping down to Wickes/B&Q and getting a paving slab.
    Will this improve things, and should I carpet the paving slab? Will this make any difference or is it just plain silly? :confused:
    Ad
  2. Dfour
    Dfour
    Jan 19, 2004
    3,998
    71
    Bracknell
    +85
    The paving slab is a good idea and will work. I dont think carpeting the paving slab will make musch difference. Try it and see. Might make it more WAF though:D
  3. bob1
    bob1
    Nov 7, 2002
    4,326
    Sheffield
    +129
    People have done this before , if it works replace it with some marble ,it will look at lot nicer ,if that matters to you/others.
  4. Dfour
    Dfour
    Jan 19, 2004
    3,998
    71
    Bracknell
    +85
    Another idea is to stick one on top of the sub as well and make a 'concrete sandwich' I have found it increases the bass responce. Makes it tighter. Again you have to tweak and play :D
  5. bob1
    bob1
    Nov 7, 2002
    4,326
    Sheffield
    +129
    Shoudn't that be a sub sandwich :laugh: .
  6. Dfour
    Dfour
    Jan 19, 2004
    3,998
    71
    Bracknell
    +85
    Yeah. can you imagine trying to find a slab big enough for thePB10 to sit on and the WAF of it!!! :eek:
  7. bob1
    bob1
    Nov 7, 2002
    4,326
    Sheffield
    +129
    :rotfl: I had some big enough for the job ,i doubt the floor could take it :nono: .
  8. rOAdeh
    rOAdeh
    Jan 24, 2003
    602
    Winchester
    +5
    auralex gramma?
  9. avanzato
    avanzato
    Jan 21, 2003
    1,881
    Norfolk
    +61
    My Nubert sub comes with no spikes but four circular foam pads for isolation, the Germans don't use carpet much on their floors. The foam is quite hard and not that compressible. You can buy them from Nubert if you can navigate a German language site or there is a thread for a DIY Gramma platform by Gary Lightfoot if you search for it.
  10. Kenny Glasgow
    Kenny Glasgow
    Apr 1, 2004
    3,346
    Livingston, Scotland
    +225
    Belgrade
    Have a look at Russ Andrew's site
    http://www.russandrews.co.uk
    His Oak Cone Feet may be an answer. They come in various sizes and can be stained/painted to suit your decor.
    He offers a 60 day money-back guarentee if not fully satisfied :thumbsup: Don't stain/paint them until you are though :D
  11. belgrade
    belgrade
    Mar 4, 2004
    137
    16
    newcastle
    Right then, chaps, I'll be off to get that paving slab then. :thumbsup:
    Might carpet it, (but I think I'll give the underlay a miss :D )
    One thing though, should I sit the xls200 on the slab, using the puck feet which it comes fitted with, or should I attach spikes to the bottom of the feet? The spikes are supplied as well.
  12. Nimby
    Nimby
    Jan 27, 2004
    9,201
    The Danish Bacon Factory
    +669
    Spikes don't like concrete and quickly wear to a blunt pencil point.
    I place a small copper coin between my spikes and my concrete slabs.
    But I strongly suggest you experiment with whatever feet are offered with your own speakers or subwoofer. You never know what you might discover. Or perhaps not. Wishful thinking is hard to ignore.
    Concrete slabs are not kind to nice surfaces and should be seperated from floors with bits of carpet or hard foam. Placing a slab on top of a subwoofer will require some protection from the rough slab. Or your pretty veneer or paint finish can be badly damaged.
    Nimby
  13. belgrade
    belgrade
    Mar 4, 2004
    137
    16
    newcastle
    I've just been down to the local B&Q's. The concrete slabs that I found were a little too big for my liking, and the space reserved for the sub. However I saw some marble and granite floor tiles. These were 30cm by 30cm, and 1cm thick. the bk is just under 30 by 30cm so will fit on these tiles.
    However will they be sufficient for the job, or does a sub need something really meaty like the concrete slabs mentioned?
    If they will do the same job as the concrete slab, I will be pleased as they are more discrete and will fit more easily into the space provided.
  14. bob1
    bob1
    Nov 7, 2002
    4,326
    Sheffield
    +129
    There's only one way to find the answer to your question and thats try it.
    If its a cheep option i would go for it.The auralex gramma metioned is a purpose built isolator and seems to work so reports sugest,but i'm not shure about down firing subs on one of these and they don't come cheap.
  15. Madskilzz
    Madskilzz
    Mar 16, 2002
    253
    Harrow
    +15
    Try a local Stone Mason or Floor tile specialist. I phoned companies local to me and found a Lebanese Granite Specialist who already had 30cm X 30cm granite tiles which were a couple of inches thick. Top and sides were already polished; the bottom of the slab was unpolished. When I explained what it was for they were most intrigued and even bevelled the edges and smoothed the unpolished side for no extra cost. £25 well spent.
  16. Smurfin
    Smurfin
    Aug 13, 2002
    20,786
    +4,157
    I asked this question of downward firing subs sometime ago, from memory the answer was "no it doesn't work". For the life of me, I can't work out why :confused:
  17. SamirP
    SamirP
    Apr 28, 2003
    1,232
    South Of The River
    +32
    Smurfin I think that Adz over came the problem of how to use a gramma effectivly with a downward firing sub, by using the Gramma upside down with a paving slab on top, so your sub sits on the paving slab.
  18. belgrade
    belgrade
    Mar 4, 2004
    137
    16
    newcastle
    Another question for any xls200 owners - If you are using the metal feet supplied with the df version, do you take the nylon screws out of the bottom of the feet, or leave them in?
    I was repositioning my sub yesterday, and I noticed that the sub was not sitting directly on the metal feet, but on the screws going through the middle. Just got me wondering whether these screws were meant to be taken out, so that the feet sit flush on the floor (or paving slab in my case).
    Will the sub not be more stable and less prone to vibration, if this is done?
    I also noticed that one of the screws fixing the driver to the unit, was quite loose. Tightened it, but found this surprising as sub is only 2 months old. :rolleyes:
  19. lowrider
    lowrider
    Sep 29, 2003
    676
    Riga, Latvia
    I use superspikes, they work (see measurement on site), look good and cost around 50 euros... :cool:
    http://www.soundcare.no/
