Best way to hook up Philips sattelite box?
Discussion in 'Satellite TV, Sky TV & FreeSat' started by sapkan, Oct 14, 2004.
  1. sapkan
    sapkan
    Jul 8, 2004
    496
    +4
    I am about to sign for a sattelite package in my country, the receiver box has two scarts as well as composite. How do I hook it up to an AV receiver that has component upconversion but no scart input. Dont want to use the composite outputs as they give the crappiest quality signal. :lease: help
  2. sapkan
    sapkan
    Jul 8, 2004
    496
    +4
    any cable/connection gurus
  3. Chris Muriel
    Chris Muriel
    Jun 14, 2002
    7,264
    Manchester
    +756
    You can buy adpator or adaptor-cables to convert (or break out) SCART to audio, RGB or S-video.
    Which exact cable to use depends on what connections your AV receiver has.
    Chris Muriel, Manchester.
