Best way to feed AE300 non-HCPC PAL signal
Discussion in 'Projectors, Screens & Video Processors' started by xander, Jan 17, 2003.
  1. xander
    xander
    Jul 1, 2002
    130
    New Zealand
    I'm starting this thread to get feedback from all those people that are _not_ using HCPCs to feed primary PAL signals to their AE300 projectors. I am trying to avoid the use of a HCPC since I use them all day in my work and would like to keep them out of my home theatre for as long as I can :).
    - what DVD player?
    - progressive scan or not (does this make much difference for PAL?)
    - de-interlacers (Brite-View, iScan, etc)?
    - cables
    - etc
    Lets see if we can come up with the best way to get a non-HCPC PAL picture on this projector.
    I'm currently feeding it with an interlaced PAL signal, via AR-brand component cables from a Pioneer DV533K. I've got the Sky digital TV connected to it via Video and that also looks fairly good. Can I improve on this?
    Thanks in advance
  2. jamesdoc
    jamesdoc
    Ok. I have no suggestions yet, but still, great thread! How is the Brite-view going? Trying to find a PAL progressive scan dvd here in "the land that time forgot" is too hard. I think I will be bringing one in from o/s. I can't stand another salesman telling me progressive scan is how fast it can fast forward!
    james
  3. jamesdoc
    jamesdoc
    So the Brite-view wasn't too hot on Pal then. I am wondering if I will get the same with the AVT-3200. Everything seesm to be NTSC biased. I think I will hang off and save $400 NZL.
  4. snocrash
    snocrash
    Dec 27, 2002
    103
    currently .. the best picture in terms of smoothness (that being motion smoothness) is currently 625i (Standard PAL via component inputs). Incidently, it's listed as a grade 1 picture in the manual. There's a small problem in that the amount of picture detail is slightly less than say a VGA based input.
    The AE300 is suffering badly because of the lack on 50HZ optimal signal inputs.
    I really want to try to get HDTV (1080i) at 50Hz input to the AE300, but have been unsuccessful so far. (Although the manual describes this input as grade 1 too)
    Don't get me wrong --- AE300 looks beautiful no matter what you feed it... I'm just being pedantic... and want perfection :p
  5. Jonny1973
    Jonny1973
    I have a AE100 and have just ordered a Philips 963SA. The 963 is NTSC/PAL Progressive scan.
    I have a HCPC and it gives a great picture but I don't want the hassle of using a PC. I got a Pro-V so I could use my old DVD player but then it died so now I going for a Prog scan model.
    Apparently the 963SA gives a better picture than the Pro-V and is close to PC quality.
    My new Philips 963SA is being delivered next monday.
  6. Seb1
    Seb1
    Sep 29, 2002
    114
    Do the Panasonic AE100/200/300 support PAL Progressive Scan?
    I recently found out that not all projectors are able to display it...
  7. snocrash
    snocrash
    Dec 27, 2002
    103
    The AE300 only supports a very very limited number of PAL (50Hz) resolutions
    and as far as I read it, supports no 50Hz progressive signals.
    :-( Typical U.S. centric way of thinking... "Oh the whole world watches NTSC" :(
  8. jamesdoc
    jamesdoc
    I seem to remember that the AE100 supported PAL progressive, so I would think that the AE300 would. If not, I won't keep wasting my time trying to get a PAL progressive dvd player.
    james
  9. Seb1
    Seb1
    Sep 29, 2002
    114
    Could someone please clarify?
  10. robocop
    robocop
    Oct 16, 2000
    648
    Old Detroit a.k.a. Chippenham. Wilts
    +23
    I'm running a AE300 (Jap version) connector to my Arcam DV88+.
    When using R2 PAL discs, 625p is displayed in the AE's picture menu.
    Hope this helps?
  11. Seb1
    Seb1
    Sep 29, 2002
    114
    What about the AE200?
    Do you think it will be more limited?
  12. xander
    xander
    Jul 1, 2002
    130
    New Zealand
    robocop,
    Do you see a difference in AE300 picture quality betw running the Arcam DV88+ in progressive PAL mode vs interlaced PAL mode (I assume it allows you to switch)?
    Xander
  13. snocrash
    snocrash
    Dec 27, 2002
    103
    robocop, are you for real ? 625p would then be an unlisted mode. I'll try it today.
    The de-interlacer on the AE300 is extremely good, and the average user wouldn't be able to pick it.
  14. snocrash
    snocrash
    Dec 27, 2002
    103
    If you are a prospective AE buyer, here's the AE200/300 compat signals:
    [​IMG]
  15. robocop
    robocop
    Oct 16, 2000
    648
    +23
    Snocrash,
    I can assure you that the AE300, and for that matter my previous AE100, both do PAL 625p.
    If you do a search, there are a couple of old threads re the AE100 accepting PAL progressive scan.
    Someone even took a screen shot of it.
    Don’t forget, that PAL P/S has only very recently only being ratified for official use (the Arcam being the worlds first player to do so). Because of this, it is extremely unlikely that all the current instruction manuals and indeed product specs are fully up to date.
    Regards
  16. snocrash
    snocrash
    Dec 27, 2002
    103
    I beleive you. Just making sure ;)
    Now it's back to the drawing board to see what "undocumented" modes exist in the AE300
