"Best" way to extend Sky+ cables?
Discussion in 'Sky Digital TV Forum' started by Bernie Steak, Sep 28, 2005.
  1. Bernie Steak
    Bernie Steak
    Sep 1, 2005
    513
    +18
    Posted this in the cables forum, but wasn't sure if that was the best place, so thought I'd try over here too!
    I know there's debate over if you should even attempt this or not (signal loss), but I'm wondering (as I already have some suitable cable).
    Would I be better of using the cable I have, four new ends, and two f connector to f connecters?
    These X 4 for the two new bits of cable: http://www.maplin.co.uk/Module.aspx?ModuleNo=10447&doy=28m9D
    These x 2 for linking them together with the current cable: http://www.maplin.co.uk/Module.aspx?ModuleNo=10447&doy=28m9D
    (about £5 in totall)
    OR, should I just buy a couple of these:
    http://www.maplin.co.uk/Search.aspx?criteria=QQ79L&doy=28m9&source=15
    (about £6 for two)
    Any views most welcome! Love this place. :D
  2. SamRadford
    SamRadford
    Jul 12, 2005
    3,965
    103
    N. Yorkshire
    +308
  3. Bernie Steak
    Bernie Steak
    Sep 1, 2005
    513
    +18
    I see products for sale that I could use to extend the cable there (like those I've linked to from Maplins) but no advice on the best of the two options as I'm considering?
  4. Nick_UK
    Nick_UK
    Nov 13, 2004
    9,748
    103
    +270
    Since the signal is digital, the strength won't affect the quality. Unless you have a really long run of cable already, adding a couple of connectors (of whatever sort) won't make any difference to the picture. With digital signals, you reach a point where it no longer works, and you need quite a large signal drop to do that.
  5. Bernie Steak
    Bernie Steak
    Sep 1, 2005
    513
    +18
    That was my understanding. The signal is good quality/strength as it is, and I "only" need an extra metre or so. Today's the day to "suck it and see"!
    :D
  6. Bernie Steak
    Bernie Steak
    Sep 1, 2005
    513
    +18
    All is well!
    Extended using the easier method above (£6 to maplins) and it's all sorted. No picture quality loss I can see, and the signal strenght/quality indicator bars are exactly as before.
    :smashin:
