Best way to convert vhs to dvd-r ?
Discussion in 'Camcorders, Action Cams & Video Making Forum' started by robbie b, Dec 1, 2004.
  1. robbie b
    robbie b
    I am wanting to convert some old vhs tapes onto dvd-r. I think I have two ways of doing this.
    1/ connect vhs player to tosh xs32
    or
    2/ connect vhs player to canon 730i camcorder to convert into digital and then from camcorder to tosh via firewire
    Does anyone know which will produce the best quality recordings ?
    Many thanks
  2. MarkE19
    MarkE19
    Aug 10, 2002
    17,261
    Rainham Essex
    +2,404
    Well either way you are starting with a low quality composite source so I doubt it will make much difference wich way you do it.
    If you want to spend some time experimenting then why not capture 5 minutes from each of your methods and burn to a disk and see which one looks best.
    Mark.
