Best way to convert DV to Computer
Raj007
Afternoon all,
I recently found my old Samsung DV Camcorder, that I found in my attic. In the box I also found a bunch of tapes too.
I already have a firewire cable and port on PC but never used it.
My point is how do I convert it with minimal quality loss?
Raj007
Thanks, the quality was sharp!!
Any idea how to compress them down?
I have saved some tapes and now it all totals up to 40gigs
sep8001
You could convert them to dvd but you would lose quality, may be best to buy a portable drive and copy onto there.
oneman
You really shouldn't lose much quality converting to DVD, I use Freemake video convertor (get v3.1.x) and its literally a few clicks. Note that DVD-R can degrade over time depending how they are stored.
40GB really isn't much, as suggested above get an external HDD and then get another another one and make a second copy.
Raj007
I don't like DVD, but thanks anyway.
next010
Install Handbrake
  • import file
  • select preset->general and for quality pick HQ 480p (NTSC) or 576p (PAL) to match source captured video.
  • hit start encode
That will put out a high quality compressed version of the videos, if you want to keep the sources USB HDDs with large capacity are dirt cheap these days.
