Best way to connect?
Merritt
I have a bit of a dilemma. I currently have sky+ connected via RGB SCART to the back of a DVD player, then RGB SCART out from the DVD player to my Panny5.
If I go ahead and buy a Denon A11, I obviously want to use component (mainly to use progressive scan) from the DVD player to the screen but im assuming that means I can't stick RGB scart into the A11 from sky+ and still be able to watch it via component?!
Sooooo - what are my options?
What is the S-video output from sky+ like? (I believe I could connect S-Video and component to the panny 5 at the same time and switch between them with the remote but I don't want to do this if the PQ is compromised)
Alternatively, if I buy a RGB to ??? converter - does the A11 accept any input that would effectively 'loop through' to the component out??
Steve
Podcast: Q Acoustics Q3030i, Humax Aura, Roku Streambar & WandaVision Reviews and more...
