Best Way to Connect Yamaha DSP750?
Discussion in 'Cables & Switches' started by yeff, May 8, 2005.
  1. yeff
    yeff
    Oct 25, 2004
    54
    Hi, just got this and was wondering what is best way to connect my Dvd & Sky+
    up to this, so that I can use the auto switching, and only use the 1 remote, any help would be great.
    My TV only has 2 scarts and an s video connection.
    This is way I have connected them but having probs,
    Sky+ & Dvd Player optical lead & s-video into amp, then s-video into TV which is AV3.
    No probs with getting picture from Sky, but when I press DVD button on Yam remote get no picture from Dvd Player only sound, but press DTV button and no probs with Sky!
    Am I connecting them up wrong? bit of a noob with connections
    Have just tried connecting the amp to TV with a component/scart cable, but not getting any picture @ all!
  2. shortone
    shortone
    May 1, 2005
    115
    Nuneaton, Warks
    Hi Yeff
    From Memory as I am at work.
    The amp will output all incoming video signal via the Componet outs on the back marked as Monitor out as this uses the video upgrade function in the AMP.
    If you are inputting via S-video and not out putting via the componets then each in-put needs to have its own output.
    On the rear where you have used the input for DVT under there is one for output and the same for Video S-video in S-video Out.
    This means you will need both scart scockets on your TV.
    I hope 1, I am correct and 2, this helps. If I am incorrect then apologies as I am working.
    Regards
    Andy
  3. yeff
    yeff
    Oct 25, 2004
    54
    Thanks for the reply Andy, I have now connected them to TV this way:
    Sky+ S-Video & optical to amp then S-Video to TV.
    Dvd straight to TV with scart & optical to amp for sound, this will do till can afford new LCD screen :D
    THX again for info :smashin:
  4. Gregory
    Gregory
    Mar 27, 2005
    312
    Midlands
    +9
    If the s-video was from the monitor socket on the Yam then it should have worked just fine (if I understood the description). If not, it might be worth checking that there isn't some bizarre menu option mis-set as otherwise there may be an issue with video circuitry in the amp. If you've just got it then it it would be good to know it doesn't have some sort of fault.
