G
Glenn Keen
I've got Sky+ being installed next weekend and was wondering what's the best way to connect it to my Panny 4TH-42PWD4 plasma?
At the momeny I'm connecting my DVD player by component connection and my video by the composite ones.
My Denon 10SE amp will take 2 different Component inputs so I was wondering if i should get a RGB scart to component lead and pipe both the Sky+ and DVD into my amp then out to the Plasma.
I could connect the Sky box to the RGB inputs on the Plasma but i beleive that you have to change the settings on the plasma and can only use the component OR RGB inputs!
Any info would be really helpful.
Thanks,
Glenn.
Thanks,
Glenn.
