best way to connect my sky box
Discussion in 'AV Pre-Amp/Processors & Power Amps' started by thelostone, Aug 28, 2006.
  1. thelostone
    thelostone
    Apr 25, 2005
    247
    nottingham
    +6
    I have a denon 1906 and at the moment i am running my sky box straight to the amp via some rca leads.The question is this would i be better off running the sound through my dvd recorder then to the amp via the optical cable.Would that give me a better sound?thanks
  2. Azzin
    Azzin
    Nov 5, 2005
    23,840
    +3,072
    Why don't you run the optical lead straight from your Sky box to the Denon?
    [Edit]-Ah-does your Sky box actually have an optical out as you don't mention which one you've got?
  3. thelostone
    thelostone
    Apr 25, 2005
    247
    nottingham
    +6
    no mate i only have sky not sky+ which as you say would be a lot eaiser:(
  4. clockworks
    clockworks
    Dec 7, 2005
    3,573
    West Country
    +297
    Looping through the DVD recorder can't possibly make the signal better. The best that you can hope for is that it'll sound the same. In reality, it'll sound worse, if it works at all.
  5. Ianfromnotts
    Ianfromnotts
    May 16, 2003
    2,760
    Nottingham
    +174
    Buy a second hand Sky+ box and just swap it over with your existing sky box, phone sky to reset the card the box and take the digital audio out into your av amp - great up grade for not too much cash
  6. thelostone
    thelostone
    Apr 25, 2005
    247
    nottingham
    +6
    Thanks for your help looks like a sky+ box is the way to go :suicide:
