Best way to connect my new pj ?
Discussion in 'Projectors, Screens & Video Processors' started by Lil in Spain, Dec 3, 2004.
  1. Lil in Spain
    Lil in Spain
    Nov 26, 2004
    45
    When I finally receive my AE700 I'm going to connect a new DVD player via HDMI/DV-I. Thats that sorted.
    But, I could do with finding out the best way to connect my Sky+. Now its connected to my TV via RGB scart, so should I connect it to my pj with S-vid (about 12mtrs of a quality cable) or should i go another avenue, like an RGB splitter etc ?
    ps I already have a JS-Tech RGB-VGA converter feeding my plasma of Sky+, so maybe this could be icorporated another way?
    :suicide: All the possibilities are confusing :confused:
    Lil
  2. Lil in Spain
    Lil in Spain
    Nov 26, 2004
    45
    It would be nice to order the cables soon :smoke:
  3. markbingo
    markbingo
    Nov 10, 2004
    819
    46
    Cambs
    +124
    Lil,
    I can only speak for myself here, as I have not tried all the different options. I connect my DVD by componant direct to the 700.
    I connect my Sky+ by s-video also direct to the 700.
    I am very happy with this set up, and selecting the source via the Projector.
    The Picture is VERY good from the DVD, and is pretty darn good from Sky+ (although obviously until Sky go to High Definition it will never be AS good)
    Hope this helps......... not sure if it will ;)
    Good luck with whatever you decide
    Mark
  4. Lil in Spain
    Lil in Spain
    Nov 26, 2004
    45
    Cheers Mark,
    I'm probably going to go the S-vid option for Sky+ aswell, how do sports broadcasts fair ?
    Lil
  5. Nick_UK
    Nick_UK
    Nov 13, 2004
    9,748
    103
    +270
    Unless you're going to go for an up-convertor to scale up to VGA/XGA, then S-Video is the best way to connect Sky+ to your pj.
