Best way to connect from DVD to TV
Discussion in 'Cables & Switches' started by tolmie, Dec 13, 2004.
  1. tolmie
    tolmie
    Dec 10, 2004
    1,100
    Glasgow
    +78
    I gettin the pioneer 575, i beleive this has a component connection on it, am i better to go componet(DVD player) to Scart(TV) or just scart to scart) and does component to scart pass thru the sound to TV aswell.
  2. Ian J
    Ian J
    Aug 6, 2001
    25,628
    +4,905
    Component connections are picture only so your best option would be scart to scart as there is very little difference between component video and RGB and the scart will carry sound as well as pictures
  3. Nick_UK
    Nick_UK
    Nov 13, 2004
    9,748
    103
    +270
    If it's true component (Y, Pr, Pb) and not just plain RGB, then you'll need an adaptor, because scart to component can't be done with a simple cable. Component video doesn't carry sound.
  4. tolmie
    tolmie
    Dec 10, 2004
    1,100
    Glasgow
    +78
    Can you tell me then,does RGB Scart carry audio and if not how do you get audio then,cheers everyone.
  5. Ian J
    Ian J
    Aug 6, 2001
    25,628
    +4,905
    An RGB scart does not carry audio so use a fully wired scart lead instead
