Quantcast
best way to connect DVD to plasma
angelislington
Hi mate,
IMO the best way would be to use the PC VGA input. You would of course need to get a convertor....
http://www.js-technology.com/rgb-vga/index.htm
...from here, but that is the best quality way of doing things. I don't think you would be able to use the 5 BNC inputs as I imagine this is RGB with seperate H & V sync. The SCART RGB output of your DVD player is likely to have sync on composite video, therefore they would be incompatible.
Hope that helps.
