best way to connect arcam dv88+ to plasma
Discussion in 'Blu-ray & DVD Players & Recorders' started by jmack, Jul 24, 2003.
Tags:
  1. jmack
    jmack
    hi
    will be getting a arcam dv88+ soon:D and was reading a bit about it ,what would be the best way to connect it to my plasma ?
    i`m going to be using component should i use yuv or rgb +sync on composite?
    what is the best way? for best picture
    cheers guys
  2. nathan_silly
    nathan_silly
    RF, via a 100 way RF video splitter, 200M length of cheap & nasty coaxial cable, looped around mains cable. :p
    Sharpness to max, incorrect aspect mode, tint to max, colour to max, contrast to max.
    hmmm maybe I should get a job in Dixons? :)
  3. jmack
    jmack
    nathan you really need to get your self a plasma and release all that bitterness;) ;)
  4. John Dawson
    John Dawson
    Jan 16, 2001
    852
    43
    Cambridge, UK
    +112
    Jmack,
    If your Toshiba plasma is a rebadged Panasonic (which IIRC it is) then I would recommend the component video connection. The DV88Plus can then be used in progressive scan mode and its deinterlacer is better in many ways than the one in the plasma. And,if you want to try the system with the DVD player in interlaced mode, then its a simple enough matter to change this over in the DV88Plus's set-up menu.
    HTH,
    John Dawson (Arcam)
  5. jmack
    jmack
    cheers john so the rgb +sync isnt a progressive scan output
