Best way to connect all my devices to a PE5120
Discussion in 'Projectors, Screens & Video Processors' started by seb4213, May 15, 2005.
  1. seb4213
    seb4213
    May 15, 2005
    25
    3
    Hi, this weekend I purchased a BenQ PE5120 Home Cinema DLP Projector (with Free Xbox!), I'm sure you all know the connections it has so I wont bore you with them.
    My question is, how should I go about connect it up to my devices, bearing in mind I want to keep the existing stuff connected to my TV.
    I was thinking of doing it like this:
    PC - DVI connection (Using a DVI splitter as my moniter is already using DVI)
    SKY+ - S Video
    PS2 - composite or is this :thumbsdow
    XBOX - might invest in the hi def and get it going through the components
    DVD - s video, of purchase another player and use hi def (although my current DVD player has a 5.1 amp built in )
    I'd appreciate any comments.
    Sam
  2. seb4213
    seb4213
    May 15, 2005
    25
    3
  3. Bolle
    Bolle
    Jan 10, 2005
    267
    The Hague
    +20
    Seeing that the Benq has a max resolution of 850 x 480, get a DVDO Iscan Ultra which wil put out that resolution (or higher with PAL sources, but downscaling should be ok with the projector) would be sufficient and offer most of these connections I believe. The Iscans Ultra come up for sale at 200 UKP or so on the forum.
  4. sniffer66
    sniffer66
    May 22, 2004
    9,789
    +3,501
    Or do what I did and converted my pc to an HTPC. Sweetspot card and Dscaler and then feed my devices into that via a scart switch. Then Its only DVI-D out to the PJ
    Thats way you dont have to settle with pants svid or composite signals, Your lowes t will be RGB.
    DVD from the HTPC will be superb
    Downside is that its a fiddlers dream (& nightmare lol)
