Best way to clean speaker units (Dali Ikons)
Scotty Pro
Hi all
after a bit of advice on how to clean the speaker units.
I have Dali Ikons as my front end for my Home Cinema system and after removing the covers to do a little "house cleaning" I noticed that the rubber edging part of the speaker has attracted a lot of dust.
What is the best way to clean it without damaging the rubber, I don't want to resort to heavy handed methods like hoovers etc ;) or is it best to leave them alone and just keep the covers on to hide the dust.
Scotty Pro
If I haven't made myself clear about what I'm trying to achieve I have highlighted the rubber bit in orange in the pic below :D
Scotty Pro
A damp microfibre cloth should be fine on that region of a speaker.
thanks :smashin:
just plain water OK or should I use a mild soapy solution ?
BlueWizard
Also, a soft bristled paint brush would work. If it is just dust, you shouldn't need any type of cleaning fluid (soap, whatever). You might consider a dusting product like 'Endust' though sparingly, and only if necessary.
A paint brush will have more give to it than cloth, and should sweep the dust away easily.
Steve/bluewizard
RBZ5416
I'd agree with the paintbrush. I wouldn't go introducing any moisture, not even a damp cloth.
