Best way to clean a Plasma?
Discussion in 'Plasma TVs' started by Froggins, Dec 22, 2004.
  1. Froggins
    Froggins
    Can someone suggest the best way to clean a Plasma, i have a PE30 37" and my niece has put her grubby hands all over it and dirted the screen, pls help!!
  2. Nick_UK
    Nick_UK
    Nov 13, 2004
    9,748
    103
    +270
    Any soft cloth and some diluted detergent should do the trick. It has to be a soft duster, though, because some can put fine scratches in the screen. If you're near a PC World store, they do screen cleaner wipes that are supposed to be very good.
  3. Techno
    Techno
    Nov 20, 2003
    312
    Mrs Techno uses some wipes which she buys to clean her spectacles - she has expensive coated, super thin thingies and can't see a flying :censored: without them so she's as careful with them as she is my screen:D
    Can't remeber the name of them but they're in a sealed pouch, a bit like those hand wipes you get in KFC.
  4. sparkz
    sparkz
    Nov 21, 2002
    219
    19
    Southampton
    My youngest used to frequently plaster his sticky little mits over our plasma :eek:
    I used water, from the kettle (filtered), on a soft cloth. If the marks were tougher I used warmer water. Never used detergents personally. Always polished it after with a glasses cleaning cloth.
    Thankfully, after you could never tell the horrors that were there before :)
  5. sparrer
    sparrer
    Down under, computer stores have wipes which are meant for laptop screens - a 2/pack containing a wet paper towel to clean, then dry with a dry towel.
    They are a bit small for a 42"plasma, but do the trick.
  6. Londondecca
    Londondecca
    Dec 21, 2003
    2,080
    +96
    Microfiber cloths are perfect for cleaning screens. Tesco sell some nice soft ones for about £1, buy 2. With a (very slightly damp MF towel wipe the screen and then use the dry one to buff.
    BTW, MF towels are perfect for removing polish or wax from your car and cleaning windscreens etc
  7. sparkz
    sparkz
    Nov 21, 2002
    219
    19
    Southampton
    Thanks for the tip. That's a lot cheaper than the usual optician type cloths I use!
  8. Londondecca
    Londondecca
    Dec 21, 2003
    2,080
    +96
    The MF towels were designed for use in 'clean rooms' in the electronics sector. I import mine from the USA :)
