Best way of joining speaker wire
Discussion in 'Cables & Switches' started by kingcutter, Jan 3, 2005.
  1. kingcutter
    kingcutter
    I am new to cinema surround and i have a system i want to upgrde however all my wires run under my wooden floor what is the best way of joining the wires together is there any special clips rather than using a joining block or black tape sorry if its a simple question. :confused:
  2. Knightshade
    Knightshade
    Aug 6, 2004
    2,004
    +43
    If you have no other choice then soldering would be the best way.
    Is there no way you can use the existing wire as 'draw wire' and pull new cable through?
  3. Peridot
    Peridot
    Aug 24, 2004
    2,979
    Newport, South Wales
    +293
    kingcutter,
    What sort of cable is already under the floor, and what system are you upgrading to?
    As Knightshade says a good soldered joint is the best. However a bad soldered joint could be much worse than other options.
    _____________________________________________
  4. Nick_UK
    Nick_UK
    Nov 13, 2004
    9,748
    103
    +270
    Joining block will work, but the screws can work loose over time, and blocks can be a hinderance if you are trying to pull cables through confined spaces. I would normally solder a join, and use heat-shrink sleeving to insulate.
  5. kingcutter
    kingcutter
    I am upgrading to a Sony DAV-SC8 i did have LG the cables under the floor are of good quality as i did think i would upgrade at some point i was going to use block but i thought there may be a better way. :smashin:
  6. eviljohn2
    eviljohn2
    Jul 8, 2002
    7,545
    Near London.
    +208
    If you're planning to upgrade soonish then the best "short-term" solution would be twisting the wires together and wrapping this in either heatshrink or electrical tape, as NickUK said. Soldering would be beneficial but I'd be surprised if you noticed a difference, if you know which end of a soldering iron is the hot one you may as well. :)
  7. 406lx
    406lx
    Nov 22, 2004
    895
    28
    Nottingham
    +27
    Whats the best way to solder the joint?
    :hiya:
  8. eviljohn2
    eviljohn2
    Jul 8, 2002
    7,545
    Near London.
    +208
    Same as soldering everything else, heat the joint (both bits), add some solder. Remove solder. Remove iron. In that order.
    Silver solder gets a little more tricky as it doesn't usually have flux cores so you if using that you might like to apply a bit of flux to the end of each wire beforehand.
