best way of cleaning a screen
Discussion in 'LCD & LED LCD TVs Forum' started by sheriffwoody, Aug 5, 2013.
Tags:
  1. sheriffwoody
    sheriffwoody
    Oct 7, 2010
    7,450
    +1,529
    Ok, bit of a daft question here, but what would be the best way to get rid off lipgloss from a tv? (tv in question is samsung ue46c7000 if it makes any difference what so ever).
    I think most of the actual lip gloss is off the screen now, but it has left smear marks all over it and some patches are still quite sticky.
    a damp cloth and a microfiber cloth? glass cleaner? baby wet wipes?
    thanks for any help.
  2. Silverblack
    Silverblack
    Sep 24, 2008
    3,068
    +578
    Baby wipes is a big NO NO!!!!!!! I'd usually use breath and a microfibre cloth, some might say use some distilled water and a microfibre cloth.
    Whatever you use just be very gentle with the strokes that you use as lcd screens are quite fragile and can scratch easily.
  3. marchudman
    marchudman
    Nov 11, 2005
    579
    Gloucester
    +80
    My experience is it depends what's on the tv. Normal dust can be wiped away by a damp piece of kitchen cloth. However greasy fingers from my kids needs more pressure or something to help it, the best I've found and have used for ages is Autoglym glass cleaner or autoglym glass polish.
    Some folks will no doubt shout in alarm but I've used the stuff for years and it cleans glass better than anything - even use it on my ipad!
  4. Insanity202
    Insanity202
    Nov 1, 2009
    15,077
    2
    3
    +4,890
    Two microfiber cloths. One wet and rung out within an inch of its life, the other dry and used to buff up the screen.
    Works a treat :)
  5. skk3
    skk3
    Sep 16, 2005
    2,544
    Rushden, Northamptonshire
    +249
    Clean the screen when it is cold!
  6. Mike K
    Mike K
    Oct 22, 2006
    61
    Somerset
    +7
    This youtube link includes some information on cleaning your screen. It starts 24 minutes in.
    HD Nation - Clean Your TV Without Destroying...
  7. Dan-h
    Dan-h
    Nov 25, 2006
    310
    28
    +33
    is boiled water left to cool down the next best thing to distilled water?
  8. Insanity202
    Insanity202
    Nov 1, 2009
    15,077
    2
    3
    +4,890
    I just use tap water. Simple and effective.
