Best video setting for 360?
Discussion in 'Xbox Forums' started by a12yon, Feb 2, 2009.
  1. a12yon
    a12yon
    Mar 14, 2005
    22
    Falkirk
    Unfortunately as I own an early X-Box 360 I am connected by a VGA cable and therefore cannot set the video setting to 1080p as when I have tried this the screen goes blank and a message in the information bar states "out of range"
    Can anyone tell me what is the best setting for the X-Box 360? I have read several threads and havent really been able to come up with a definitive answer.
    Most are saying 720p, but as this is not an option in my 360 settings menu I presume I should be looking for a resolution like * x 720??
    Any help would be greatly appreciated!!
    :lease:
  2. stug45
    stug45
    Jan 25, 2009
    57
    +4
    what are you connecting it to?
    my monitor has a 1920x1200 res and that worked fine.
    find out the native resolution of the screen you are using and try that.
