Best VGA for 360 @ 1080p
Discussion in 'Xbox Forums' started by Rochfordrambo, May 1, 2007.
  1. Rochfordrambo
    Rochfordrambo
    Feb 20, 2007
    50
    11
    essex
    +3
    Going too start using the 360's vga after the spring update i have a cheap vga cable (joytech) which is not great compared to component but i think a better quality one would be better (upscaling and no overscan) any 1 got any info ;)
    thanks
  2. SkilledNutter
    SkilledNutter
    Mar 14, 2007
    3,539
    Newport
    +395
    I tried a couple of cables and ended up sticking with the Official one as none of the others where any different in picture quality, its so clean and crisp in vga mode its really hard to tell the difference if there is any which i would say there was not.
  3. youngsyp
    youngsyp
    Nov 5, 2006
    6,278
    5
    Silverstone
    +1,556
    I've got the official VGA cable running between my 360 and Sony W series panel and it made a marked difference over the official component cable. There was more detail visible and, the colours became more vibrant. Of course, the resolution did go from 1080i to 1080p at the same time however, from the distance I view the panel from, I shouldn't physically have been able to see the difference in resolution. It definitely got better though :smashin:
  4. peahead
    peahead
    Dec 14, 2002
    3,140
    St.helens
    +447
    I have both the official vga lead and the monster vga lead and the monster one comes out on top for me but it is rather expensive.
  5. mpn
    mpn
    Apr 22, 2006
    8,062
    Stockton
    +575
    The only thing, in my opinion anyway, that the monster has over the official is a higher price tag, ive had both running and cant see any diference at all.
    The official one is just as good in my view.
  6. peahead
    peahead
    Dec 14, 2002
    3,140
    St.helens
    +447
    What size tv do you have its only Noticeable on larger size screens 40" and above.
  7. mpn
    mpn
    Apr 22, 2006
    8,062
    Stockton
    +575
    32" Toshiba so probably couldent tell ....
  8. Rochfordrambo
    Rochfordrambo
    Feb 20, 2007
    50
    11
    essex
    +3
    thanks guys at the mo my vga looks washed out i have the samsung 40" 1080p and am using the monster component its great cable but dont like the overscan i get and i want the component for the wii so it looks like i will go for the mons:thumbsup: ter vga .
    Once again thanks for the input guys :thumbsup:
  9. kmark40
    kmark40
    Jul 6, 2006
    1,354
    Antipodes
    +42
    I have the same tv and can HIGHLY recommend the MS VGA lead
