best version of max pane 1 & 2: x-box or ps2
Discussion in 'Playstation Forums' started by 7 of 9, Dec 20, 2003.
  1. 7 of 9
    7 of 9
    Apr 16, 2003
    235
    16
    kingswood bristol
    i have recently rented this and really enjoyed it and will definitely buy this but don't know which version to get x-box or ps2?
    i have got the january issue of gamesmaster magazine, and in there they gave it 90% score, but graphics review was slightly confusing
    so which is best version xbox or ps2 as far as graphics are concerned?
  2. 7 of 9
    7 of 9
    Apr 16, 2003
    235
    16
    kingswood bristol
    which is the best version of max payne 1 ps2 or x-box or is there no difference?
    thanks from 7 of 9
  3. james.miller
    james.miller
    Dec 16, 2002
    2,616
    +143
    xbox - graqphics are better. other than that, there really isnt a lot in it.
    same goes for max payne 2. BTW you really dont need to make two threads on this.
  4. captaineyecatch
    captaineyecatch
    Feb 9, 2002
    2,013
    38
    South of Heaven
    +21
    The loading on the ps2 version of max 2 is awful according to the reviews i've read - Get the xbox versions if you can.
  5. Messiah
    Messiah
    Apr 22, 2002
    7,616
    +338
    It's awful on the Xbox version as well. Every 10 seconds or so as you move from room to room etc it loads as though it's a new level. Absolutely awful and damned irritating. Only played it for 5 minutes and that was enough as 4 of those minutes was loading times :(
  6. Taz
    Taz
    Theads merged.
  7. Miyazaki
    Miyazaki
    Sep 10, 2003
    14,391
    +850
    Get the Pc version mate.
    Much better with mouse and keyboard that fiddly gamepads.
