Best value 32-37" plasma?
Discussion in 'Plasma TVs Forum' started by jayr6666, Sep 11, 2007.
  1. jayr6666
    jayr6666
    Feb 26, 2006
    519
    newcastle
    +18
    Hello everyone,
    I'm(or rather,my father)looking to replace an ageing crt with a shiny new plasma and i really want as much info and advice before taking the plunge.The panel must be 32" - 37",obviously be hd ready,one hdmi would enough but it should have component and at least two scarts(one rgb),no dvi is needed.Any plasma of this size(in particular the newew models)should have this spec anyway but as its for my parents i want a very good value set.Any ideas?The pannys look good but do the purple snakes still exist?All advice and info is greatly received.
    Cheers.
  2. jayr6666
    jayr6666
    Feb 26, 2006
    519
    newcastle
    +18
    Oh,yeah,forgot to mention the budget.£500-£750.
  3. alanksup
    alanksup
    Jun 24, 2007
    73
    +7
    I have had the 37PX70 for 5 months now, no purple snakes or screen burn. Great freeview and excellent hi def
  4. alanksup
    alanksup
    Jun 24, 2007
    73
    +7
    you can get one for £750 ish (table stand) even from the big retailers like Dixons. Less if you look about.
  5. jayr6666
    jayr6666
    Feb 26, 2006
    519
    newcastle
    +18
    cheers.so does it come with an av stand or the stand just for the set?
  6. alanksup
    alanksup
    Jun 24, 2007
    73
    +7
    you can get panel alone, with a table stand or with a cabinet stand.
  7. jayr6666
    jayr6666
    Feb 26, 2006
    519
    newcastle
    +18
    Any other makes to rival the panny?Anyone?
  8. yetanotherbob
    yetanotherbob
    Mar 22, 2007
    637
    28
    London
    +55
    No one else makes a plasma of 37" inches or less
    Get a 42" they shrink remarkably quickly
    Bob
  9. The Gooner
    The Gooner
    Dec 5, 2004
    1,390
    48
    NE Lincs
    +44
    hitachis used to make a 32" plasma but dont think they do any more,
    just took a quick look at currys and comet web sites and the only 37" plasma is panasonic, so that makes it easy,
    Panasonic PX70 is good 37" plasma
  10. jayr6666
    jayr6666
    Feb 26, 2006
    519
    newcastle
    +18
    lcd then?Or am i blaspheming?
  11. choddo2006
    choddo2006
    Dec 30, 2005
    8,528
    +542
    Personally, I'd get the 37PX70 ahead of any 32" LCD. And any 37" LCD for that matter.
