Best upgrade step from Denon AVC-A11SR
Discussion in 'AV Pre-Amp/Processors & Power Amps' started by tjobbins, Aug 10, 2005.
  1. tjobbins
    tjobbins
    Jan 1, 2005
    157
    16
    Harpenden
    Hi guys,
    Here's my current setup 7.1 setup:
    Denon AVC-A11SR integrated amp
    Fronts: Dynaudio Contour 1.3 MKIIs
    Centre: Dynaudio Contour Centre
    Surrounds: Dynaudio Audience 42
    Surround Rear: Dynaudio Audience 40
    Sub: Rel Quake (plan to upgrade this too shortly)
    I've only just bought the Contours and haven't even picked them up yet. But I realise my current Denon is perhaps a little underpowered to feed these hungry 4ohm speakers. This lead me to think that perhaps a power-amp would give a quality boost to my system.
    So I was wondering if anyone could give me some thoughts as to what next step to take in my system. With a budget of £800 or so, should I:
    1. Get a power amp, feeding it from my Denon which would remain in use as my pre-amp
    2. Get a pre-amp processor and continue using the Denon as my power amp.
    (note I am assuming I will buy second-hand to maximise my buying power)
    Given my new Dynaudio Contours which I know to be hungry, the poweramp definitely seems the beter choice - I mention the processor because it crossed my mind that perhaps with advances in digital technology, this could provide a better quality improvement. I also thought about a pre-amp because I would love Room EQ, tho this appears to be quite a way out of my budget.
    Ideally I would look for a 7 channel poweramp, however it would also be an option to get just a 5 channel amp if this would allow me more power/quality for my budget. If I did just get 5 channels, I would then continue running my surround-rear channels from the Denon, and the remaining 5 channels would come from the new poweramp.
    Given my Denon is currently 125W into 8ohms, I assume I would want a new poweramp to be at least 150-200W into 8ohms, so as to provide the necessary power boost.
    I will use the system heavily for movies, but also I listen to a lot of stereo music too. My dedicated HT room is small - 11' by 10'.
    Any thoughts much appreciated!
    Tom
  2. tjobbins
    tjobbins
    Jan 1, 2005
    157
    16
    Harpenden
    One other option occurred to me.. given that my Contour 1.3 MkIIs are particularly hungry, and I do listen to a lot of stereo music - I could always get a high-end, high-powered stereo power amp which I use purely for these speakers. The remaining 5 channels would continue to be driven from the integrated Denon amp.
  3. tjobbins
    tjobbins
    Jan 1, 2005
    157
    16
    Harpenden
    I'm actually warming to this theme. A pair of Tag McLaren 125M monoblocs for example:
    http://cgi.ebay.co.uk/Tag-Mclaren-1...5796604579QQcategoryZ3280QQrdZ1QQcmdZViewItem
    Monoblocs would also give me the advantage that, at a later date, I could add more monoblocs and upgrade each of the other 5 channels in turn (centre first)
  4. Jase
    Jase
    Mar 16, 2001
    9,530
    UK
    +930
    Add Poweramps, either a three or five channel job and let the Denon run the remaining Surround Channels. The Denon makes a fine Pre-Amp/Processor. :)
