Question Best ultra thin wall mount for oled55b7v
Discussion in 'LG TVs Forum' started by beerglass007, Jul 12, 2018.
    1. beerglass007
      beerglass007
      Sep 5, 2005
      768
      28
      UK
      +35
      Evening all
      Whats the best ultra thin wall mount for oled55b7v
      Been looking on amazon and can't see much, just need a simple wall mount
    2. crypticc
      crypticc
      Dec 28, 2007
      671
      44
      +233
      Partially or fully Articulated or not at all ?
      I'd start here. I have the SANUS VLF320 FULL MOTION which is aasemi-pro mount and buil like like a tank with cast aluminium pieces but reasonably flush. Unfortunately I'm too chicken to compress into super flush mode for fear of amount of pressure needed on front could bend screen. (II did it once pulling from behind with assistance from the other side and it does get closer).
      Bu on the other hand I have no concerns with extending screen out at about 45° or more to the wall when wanting to aim TV towards dining area. 65" screen that far out from the wall is something to behold
      You searched for Sanus wall mount - Red Apple Digital
      I would also just add that the slight thickness of the bottom piece which holds the electronics, plus depth of any bracket spacers means you will get some "floating screen" effect no matter how slim the mount.
      Chris
    3. crypticc
      crypticc
      Dec 28, 2007
      671
      44
      +233
      Update: just needed to tweak the internal friction plates to get the mount to go into slim mode. Here's photo. You'll notice the limiting factor on this joint is the lower support vs the T-shaped rear cable tidy in the centre of the speaker bar. Shorter bolts would be possible if that were removable.
      A simpler mint that didn't need to be articulated and therefore without that centre component of the amount may not have that concern in the first place
