Hi Everyone,
I need some advice on the best TV set up for a home Gym. I want to put a large screen (+65”) on the wall hooked up to a sound bar. We want to use zwift for cycling and Les Mills for exercise classes. ideally we want the simplest setup possible, which doesn’t involve loads of different kit, relying on multiple controls etc. Any suggestions or advice gratefully received.
1. Can I run zwift directly through the apps of a TV?
2. Are there any TVs to be recommended? Any to avoid? (Budget no more than £1k)
3. Would a computer hooked up to the tv be better?
4. Do I need Apple TV?
Many Thanks
Marcus
Many Thanks
Marcus
