Best TV out of these?
robloxian
Hi, I currently have this TV:
I'm wanting a bigger screen, and my budget is £400ish, but can't decide between these two:
LG 50"
LG 49"
My questions are:
Are these two TV's any kind of visual performance upgrade from what I have now?
Does a G energy rating mean terrible performance, or just uses more power?
IPS or VA?
Thanks.
vickster
50 is VA, 49 is IPS
tvdavid
the 50 inch lg
vickster
I thought IPS was better than VA?
@tvdavid why the 50" out of the two?
Depends what you mean by better? Blacks and contrast are better on VA. IPS if viewing at an angle.
Have you reviewed the Best Buy guide?
vickster
I haven't no.
Why did you suggest the 50?
I didn’t...
Guide is here
No £400 TV is going to be great (certainly not for HDR). What are you using it for? Are you going to be sitting at the same distance or further away for the bigger screen?
robloxian
I didn’t...
Guide is here
Sorry yes I saw that.
What do you think out of the two?
vickster
I’d get the 50” as it comes from a good retailer with a 5 year warranty. As above, what are you actually watching/using the TV for. Ultimately, I doubt either are much of an upgrade. Just bigger and being bigger, flaws might be more obvious
robloxian
Mainly Sky Q, Blu-ray, and PS4/PS5.
I don't think I'll get much better for my budget.
Do you think there will be visible flaws?
vickster
Certainly for HDR, quite probably with motion handling too, possibly screen uniformity.
Cheaper TVs come with compromises (although there’s no perfect Tv at any price really).
Did you read the guide? The 49” doesn’t even make the guide I think.
Does it have to be an LG?
Dodgexander
Make your choice based on preferred panel type first, some people still find a need for IPS panels, some people prefer VA. Steps to take before picking out specific models are in the opening post of my guide:
With your budget you can expect similar quality to your current TV, you won't find something a lot better for 400.
robloxian
It doesn't have to be. I'd go for Samsung or Sony.
robloxian
I'm happy with the quality of my current one.
The 50 I'm interested in I can't seem to see if it's VA or IPS. A few sites say one and the other.
Viewing angles are important for me due to the layout of my room.
vickster
VA which is why it’s under TVs with narrow angles in the guide (low tier). 50s are VA as I mentioned above
robloxian
What about energy rating? The 50 is G rated. Is it literally that it just uses a bit more electric than normal? Not hundreds though?
vickster
Yes, but only in HDR mode. Did you read what it said on the JL site (click on the i for info).
It’ll be a little extra a year possibly maybe depending on your use, but LCD TVs don’t use a lot of electricity. Turn it off when not watching
robloxian
Yeah I did. JL says wide viewing angle?
I thought it was VA? So confused! Will it look awful when viewing it at a slight angle?
vickster
Not if slight no, I think you’re usually ok up to 30deg
robloxian
My current TV is IPS and as the TV is at a slight angle, things look good.
My concern is that if I get a VA TV, I might be disappointed when sat at an angle watching it.
vickster
Some more reading...
vickster
How slight an angle. I have a VA TV. I can stand to the side and it’s still watchable. Not ideal but not that awful!
robloxian
Latest News
Magico announces Titan 15 subwoofer
  • By Andy Bassett
  • Published
Ajax Systems adds UK Socket to expand smart home options
  • By Andy Bassett
  • Published
Best TVs of 2021 - Editor's Choice Awards
  • By Phil Hinton
  • Published
Melco update improves N10, N100 and N1 EX digital libraries
  • By Andy Bassett
  • Published
Loewe launches We.See TVs under new 'We. by Loewe' sub-brand
  • By Andy Bassett
  • Published
