Best tv for gaming
Raevyth
Hello,
My partner and me bought a ps5, which gonna be used on our main samsung tv. We would like to buy a secondary gaming tv to use on our old ps4 (to play games together). We can't afford to spend as much as our main tv for a secondary one, so we were looking at not too expensive tv. I found these in our budget:
- HISENSE 43A7300FTUK 43 inches​
  • Philips 43PUS7505/12 43-Inch
  • Philips 43PUS7555/12 43-Inch
  • Philips Ambilight 43PUS8545/12 43-Inch
  • Panasonic TX-43HX700B 43 inch
- Samsung 2021 43 inch AU7110
How would you rank these tvs from best yto worse for gaming purposes (including picture quality)? Also, if you have better ideas under 300-400 pounds and about 43 inchese welcome to suggest. Thanks
tvdavid
I would go
Samsung
Hisense
and the Ambilight ones
Dodgexander
Have you see:
First decide whether you want an IPS or VA panel on your TV. Hisense (VA) and LG (IPS) are usually best value at smaller sizes.
If you want to push the boat out for better motion there's also the 43" Sony XH80/XH81 series with 120hz panels. They use IPS panels.
2021 models are currently overpriced, not worth considering unless you have specific need for one over a 2020 model.
