Best Tv For £700
Discussion in 'General TV Discussions Forum' started by Jez, Dec 21, 2003.
  1. Jez
    Jez
    Oct 30, 2003
    468
    19
    Lincoln
    Have come into alittle money so want to upgrade my tv.
    What are the opinons guys have around £700 to spend :)
  2. Kahless725
    Kahless725
    I have the Panasonic TX28PS12 which I think is a fantastic picture and a good 100Hz set as I have it in 100Hz mode all the time and have not seen any artifacts.
    The picture is good weather it be composite or RGB (of which there are two RGB scarts)
    The sound is really good for watching sky on with good bass and a good sound option that adds a little more depth called ambience.
    Also the set auto formats and auto zooms depending on what your watching.
    I got mine from www.empiredirect.co.uk they do the TX32PS12 which is the 32 inch version for under £700 and if you have the transport and live near Leeds you can ring them and order it and pick it up from their warehouse Monday or Tuesday night as they open till 7pm. (And you save the postage) (Take a friend though cos it will be heavy)
    Regards
    Robert.
