Hm, just checked out your Flickr! It's amazing
I think I'll be making that kind of photos. Mostly naturalistic things. I hope you understand, since i'm uber newb in here.
Thanks for the compliment
I've been using mirrorless cameras for many years.
I currently use an Olympus OM-D E-M10 Mark II - generally I'm using the Olympus f2.8 12-40mm PRO zoom lens, sometimes the Olympus f1.8 17mm prime (fixed zoom).
Before I got the 12-40 I mainly used an Olympus 14-42mm EZ pancake zoom lens.
There are mark 3 and 4 versions of the same body - but apart from 4K video they don't add many features I care about.
If you're OK with buying used then the E-M10ii body starts around £200
Search used cameras and lenses from over 100 UK, European and United States retailers. Price comparison for used digital, film, lenses, medium and large format cameras
usedlens.co.uk
The 14-42mm EZ lens starts around £110.
usedlens.co.uk
I like the Micro 4/3rds system from Olympus because the bodies and lenses are comparatively small and lightweight. The sensor is fairly large and the bodies have inbuilt stabilisation so you can take photos in situations where the light isn't great.
There are lots of other options out there - unfortunately it's not a great time to try out cameras due to COVID.
On a plus side the black friday sales events are likely to put out some bargains soon.
