Best tape for ET recording
Discussion in 'Digital TV & Video Players & Recorders' started by Garrett, Jun 25, 2001.
Tags:
  1. Garrett
    Garrett
    Apr 21, 2001
    43,640
    2
    167
    The best thief you'll never see.
    +8,406
    What is the best tape for ET recording (no not extra terrestrial) on a Panasonic 960 or any machine with ET VHS and how does it compare with S-VHS. I have tried TDK EHG Hi-Fi and found the result very poor and got better results on entry-level tapes, but non-matched normal recording.
  2. samhassall
    samhassall
    Stick with S-VHS tapes. S-VHS ET is a bit of a gimmick in my experience.
  3. ABP
    ABP
    Got to agree with TOSHI I have the 860 ET...waste of time go for S-VHS tape every time, it's the only way to go and the tapes are not that expensive if you use them and the quality is not in the same league. The Standard VHS recordings are better than the S-VHS ET nomater what tapes you use and I have tryed lots.
  4. mart.stokes
    mart.stokes
    Got to agree with both of the above observations. If you are having to ask the question about which tape is best then you may as well buy S-VHS tape in the first place!
