best system for money
Discussion in 'Home Cinema Speakers' started by harryh44, Feb 13, 2009.
  1. harryh44
    harryh44
    Jan 20, 2009
    44
    11
    Northants
    +6
    All,
    Looking for your thoughts on which speakers to purchase.:lease: Have a budget up to £1500. Use is 90% movies, very little music. Would prefer black. I have attached a layout. Any suggestions would be appreciated. :)
  2. Andrew K
    Andrew K
    Oct 14, 2004
    3,392
    +608
    have you had any thoughts on size of speakers that work for you. For instance you can get an excellent Monitor Audio set-up for the budget you have in mind with a mix of floorstanders/bookshelf etc or you can go down the sub-sat route?
    Also what amplifier are you thinking of running?
  3. harryh44
    harryh44
    Jan 20, 2009
    44
    11
    Northants
    +6
    I have a pioneer vsx1018 amp/receiver. I would lke a sub, centre, 2 fronts (floor or book) and two small inobtrusive rears. Any suggestions? :)
  4. Robsk1
    Robsk1
    Sep 24, 2007
    1,125
    Exeter
    +122
    You need to audition a few packages so your ears can decide.
    But you may want to consider
    M&K
    Something for a larger room here
    Anthony Gallo
    Linn
    Take a look at the XTZ power buys here
    There are more from B&W, Kef and others but the best piece of advice is to go out and listen at a local dealer.
  5. Andrew K
    Andrew K
    Oct 14, 2004
    3,392
    +608
    I'm going to suggest something like this :-
    Monitor Audio Silver RS1 AV Speaker Package - Quantum Electronics (UK) Limited
    or you could go to RS6 floorstanding fronts and drop the rears to the Bronze set-up.
    If the rears don't work aesthetically you could use the Radius HD rears with the system. Although for performance I would try to stick with the FX rears if you can.
