best sub cable
Discussion in 'Cables & Switches' started by andhoey, Oct 1, 2004.
  1. andhoey
    andhoey
    Jul 23, 2004
    80
    9
    lookin for a bit of advice please. i have an active sub which came with the tannoy fx5.1 package. it is connected to my amp with single phono rca cable and into the sub left analogue input. the thing is i'm needing an 8m length of phono cable.
    tvcables.co.uk. does a digital coaxial cable in this length, could i just use that?
    would there be any difference in sound between a good quality phono cable or just an el cheapo? :) any info would be great . :smashin:
  2. MarkE19
    MarkE19
    Aug 10, 2002
    17,312
    Rainham Essex
    +2,425
    8m for £53 Here and it is a dedicated sub cable.
    Mark.
  3. andhoey
    andhoey
    Jul 23, 2004
    80
    9
    so i take it that there is no difference between a digital coaxial cable and a rca phono then
  4. bobbypunk
    bobbypunk
    Yes and no. For this purpose digital coax and sub cables with RCA plugs are the same thing but they are 75ohm cables unlike standard phono cables.
  5. himpressive
    himpressive
    Sep 28, 2004
    82
    11
    Hemel Hempstead, Hertfordshire
    +7
    Hi Mark,
    what would be the best cable you have for connecting sky+ to sony dav sc8 home cinema system, and how much is a 1m run of it?
  6. laurence harvey
    laurence harvey
    argus extra do a 10 metre sub cable for £9.99 !!!!! just bought one, seems good quality
