Best sub £150 prog scan for Sanyo Z1???
Discussion in 'Blu-ray & DVD Players & Recorders' started by Gee, Oct 20, 2004.
  1. Gee
    Gee
    Jan 24, 2001
    204
    Stockport
    +5
    Hi all,
    I've decided to replace my aging Toshiba SD2109 for something with progressive scan so that I can get the best picture out of my Sanyo Z1. I have seen the glowing reviews on the Pioneer 575 but there is a mention of jaggies and that's what I am trying to avoid. Any feedback from 575 owners or any other suggestions are welcome!
    Thanks,
  2. Ed Selley
    Ed Selley
    AVF Reviewer
    Jun 26, 2003
    11,230
    2
    +3,722
    The Toshiba SD240 has the sort of build I associate with sandwiches but does have a good PS picture and can be found for under £80. Yamaha's cheapie also comes well recommended.
  3. Gee
    Gee
    Jan 24, 2001
    204
    Stockport
    +5
    Don't Toshibas usually have problems playing RCE films as I know my current model does?
  4. andrewmellor
    andrewmellor
    Dec 17, 2002
    1,537
    38
    Nottinghamshire
    +23
    Have you considered something like the Momitsu V880 that will upscale to 576p/720p/1080i etc and you can also create custom settings and timings to suit your Z1 native resolution?
  5. Gee
    Gee
    Jan 24, 2001
    204
    Stockport
    +5
    I've not really heard anything about the momitsu player, is it any good and where can you get them from?
  6. Gee
    Gee
    Jan 24, 2001
    204
    Stockport
    +5
    I quite like the look of the Pioneer 575 or 470 but I can't seem to find anywhere with stock. My local RS seem to think they are getting some in on Tuesday but I wouldn't want to bet on it!
  7. Chris Drake
    Chris Drake
    I'm running the 575 Pioneer through a Benq 6200 DLP in prog mode. Stunning in every respect. Set up as 100" diagonal, I've no critisisms what-so-ever. In terms of PQ, the Pioneer seems to be the price/performance winner right :thumbsup: now. Pity about the DVDA/SACD......but that's another thread!
  8. Gee
    Gee
    Jan 24, 2001
    204
    Stockport
    +5
    Hi Chris,
    Thanks for your post! I'm not too bothered about SACD or DVD-A so I might go for the DV-470 which I believe it exactly the same as the DV-575 but without the extra music formats. I've just got to find someone with stock!
  9. Gee
    Gee
    Jan 24, 2001
    204
    Stockport
    +5
    It looks like Richer Sounds have come through in the end! Just rang my local branch and they are reserving me a DV-575 @ £119.95 (matching their on-line store). :clap:
    I was going to get a DV-470 but I couldn't find anywhere that would ship it to my work address so I thought better of it.
    I will post my thoughts on the DV-575 once I have got it all set up.
    Thanks for everyones input!
  10. mr ooops
    mr ooops
    Mar 4, 2003
    3,657
    103
    Hardwicke and Wotton
    +349
    doh supposed to hit new thread not reply :(
