Best sub £150 PAL/NTSC Prog Scan Player ?
Discussion in 'Blu-ray & DVD Players & Recorders' started by andyboy, Jan 28, 2005.
  1. andyboy
    andyboy
    Can anyone suggest a top performing PAL/NTSC Prog Scan player for £150 or less ? so far I have found these :
    Pioneer 575A (I own this and wish to replace due to PAL Prog performance)
    Denon 1710
    Toshiba 340E
    Any others ?
  2. Raze
    Raze
    Dec 21, 2003
    874
    UK
    +13
    What will you be using it with? a CRT?
  3. andyboy
    andyboy
    Yeah - a JVC HV28P37SJE to be exact mate ! :thumbsup:
  4. Raze
    Raze
    Dec 21, 2003
    874
    UK
    +13
    340e will give u flicker free picture but the 575 has more features and apart from the flicker is excellent otherwise.. it's whether u can live with the flicker or not!
  5. Barnetto
    Barnetto
    Jan 5, 2005
    69
    What is the flicker on the Pioneer 575A that you mention? I was just on the point of buying one of these to use with a Sharp LC26G3 having seen all the good reviews (and having decided that the benefits of using the DVI over the component is not really worth the extra cost).
