Best Stereo Speakers for 2k?
Discussion in 'Hi-Fi Stereo Speakers' started by KarlRobinson, Dec 8, 2003.
  1. KarlRobinson
    KarlRobinson
    Jan 8, 2002
    159
    16
    Bedford
    Who's going to give me their preference?
  2. CYRUStheVIRUS
    CYRUStheVIRUS
    Jan 25, 2003
    1,304
    41
    Brighton
    +14
    check out PMC range, very good and have a link up with BRYSTON
  3. Crustyloafer
    Crustyloafer
    Sep 12, 2003
    9,501
    Edinburgh
    +1,237
    Try a pair of the Acoustic Energy AE1Mk3 Reference monitors. I have a pair which are partnered with a Cyrus DVD8 + PSX-R and a Cyrus 8 + PSX-R. Sounds pretty damn good. They are fantastically detailed but never sound harsh and the bass is very tight.
    [​IMG]
  4. Cool-hand
    Cool-hand
    Jan 5, 2002
    2,105
    Portsmouth / Middle East
    +77
    seconds hand or new kef ref speakers (old type without hyper-tweeter)
    ATC SM35's - Horsham hifi have em @ £1700
    If your prepared to import goto Audiogon and buy used Thiel speakers CS1.6, CS2.3, CS2.4, CS3.6 these are excellent speakers and Stereophile magazine said the the CS2.4 are one of the best speakers in the world. New price £3500 but second hand 2000 - 2500 dollars (bout £1500 - £1800)
    here:-
    http://cgi.audiogon.com/cgi-bin/srch_fs.pl
    CH
  5. Matt F
    Matt F
    Jul 18, 2000
    900
    Chester, UK
    +4
    Spendor ought to be on your list - it would certainly be on mine if I had £2K to spend. I think SP1/2's would be in this price range (pictured below). If they're too much then check out the SP2/3E - both fantastic, classic speakers that give you the music.
    Matt.
  6. dts_boy
    dts_boy
    Nov 26, 2001
    2,536
    Manchester suburbs...
    +141
    under your budget, but i think monitor audio gold reference 20s are awseome floorstanders at £1500. they have a new silver finish which looks nice but is dearer, i think?
  7. Spligsey
    Spligsey
    Jan 16, 2003
    2,069
    UK
    +137
    I know a few people who rate Harbeths Monitor 30 pro's
    Check them out here
    Asthetically, they wont make the missus jump for joy, but apparently, they make some fine sounds.
    Adz
  8. 337GUS
    337GUS
    Nov 1, 2000
    630
    NE Scotland
    +18
    Monitor Audio Gold Ref 20's :smashin: Also consider the 60's at £2.3K
    £2.5K Martin Logan Clarity (need a good amp - Krell, Bryston, MF etc)
    What's the rest of the system?
  9. KarlRobinson
    KarlRobinson
    Jan 8, 2002
    159
    16
    Bedford
    Haven't got an amp yet, so the rest of the system is open.
    What does anyone think of the new B&W 700 series.
  10. sticker
    sticker
    Jan 14, 2003
    1,152
    36
    Sydney, Australia
    I'll second the PMC, especally the FB1
  11. alexs2
    alexs2
    Nov 13, 2002
    13,895
    +1,674
    B&W 805/804s would fit that price range,as would the Wilson Benesch Arc,which is also a very nice speaker.
    The only proviso I have re: the PMC's is whilst the bass is extended,it's a bit on the slow side for me anyway,and as mentioned above,the ATC's are also well worth a look.
    Just be sure to try as many as possible in your own home before buying.
  12. marck
    marck
    Jul 10, 2002
    600
    London
    Pair of Martin Logans - either the Clarity or 2nd hand pair such as Aeon's - you wont go back to a box speaker!
  13. alexs2
    alexs2
    Nov 13, 2002
    13,895
    +1,674
    Also very good advice.....and if going down the ELS route,also take a look at the newer Quad ELS's,some of which can be had a decent prices secondhand.
    Also bear in mind that some speakers,notably the B&W Nautilus range and certainly most electrostatics can present a very difficult load for your amps.
  14. NicolasB
    NicolasB
    Oct 3, 2002
    5,872
    Emily's Shop
    +564
    A bit out of your price bracket at £2.5K, but very lovely indeed at the price, are B&W Signature 805s.
    If you're going to partner them with a decent subwoofer then you should also consider speakers from the M&K "professional" range. £1400 would buy you a pair of 2510s, or £2800 a pair of active 2510Ps (expensive, but obviously that includes all the amplification you need for both speakers).
  15. Godfather
    Godfather
    Feb 12, 2001
    2,223
    63
    Edinburgh
    +224
    No one has mentioned Dynaduio yet so I will. Either the 1.3SE or the 25th Anniversary edition would be on my short list if I had money to spare.
  16. stebbo
    stebbo
    Nov 28, 2003
    174
    16
    Basingstoke Hanmpshire
  17. texasboy
    texasboy
    Sep 16, 2002
    390
    +15
    Proac Response D15 are pretty cool at about £1800
