Best Speakers for DENON AVR2105/2805
Discussion in 'Home Cinema Speakers' started by camorra, Aug 21, 2005.
  1. camorra
    camorra
    Aug 12, 2005
    625
    +29
    Hi Guyz
    I am in the process to buy a Denon AVR215 or 2805 but I am a bit confused which speakers sound best with Denon's powerhouses.
    Was thinking about Canton........any suggestions please ?? :lesson:
  2. phillfyspoon
    phillfyspoon
    Oct 21, 2003
    2,128
    Hampshire
    +76
    the best speakers would be whatever is in your budget the monitor audio silver range can be had at very good prices right now
  3. chalkstorm
    chalkstorm
    Jan 19, 2004
    429
    Rugeley
    +8
    I am also looking at the 2805 - with Monitor Audio Silvers (RS8s, LCR and FX) to create a 7.1 system. The speakers came highly recommended from my local dealer...
    Regards
    Si
  4. Sniper
    Sniper
    Apr 27, 2004
    1,294
    +80
    as mentioned the MA Silvers (end of range now) can be had @ very good prices & they're WAY ahead the Cantons !!! But they are somewhat bigger too!
  5. Jake James
    Jake James
    I think it depends upon which canton's you are comparing them to ;)
    Camorra - if you need any info about the canton's, please feel free to contact me.
    Regards
    JJ
