Answered Best speaker upgrade from an entry level setup
Heng
Current setup: wharfedale diamond 220 , smsl sa-50 , definitive prosub 800.
Hi guys, does anyone have suggestions for a significant upgrade to the wharfedales in the £500-700 range.
It is for music listening (mostly jazz and guitar based), moderate volume only out of courtesy to neighbours. I generally like a warm sound.
I'm currently in near field setup on desk but no problems if stands will be required. Active or passive both ok.
DT79
Have a look on ebay for some second hand AVI DM5 or Acoustic Energy AE1 Active. Should be able to find some within that budget. I know the DM5s and they are fantastic. The AE1 Actives have a great reputation. I highly doubt you could better either of those with amp/passive speakers without spending significantly more.
Heng
Thanks for the response, i will check those ones out.
Do you think going from near field to mid field (with stands) will be a good improvement?
Im thinking it must open up the soundstage.
my room is 3 metres wide and 7 metres long.
currently my speakers only sit 1m apart on desk
muljao
I can't help but think it should be the amp that you upgrade
DT79
It depends where you’re going to listen from. If you’re typically in a seat some way back, then yes, try to get the speakers and your listening position on roughly an equilateral triangle.
By the way, you are going to need a preamp if you go with active speakers (unless you get some with a preamp built in, which neither of the ones I suggested have, and I think may be too expensive for your budget). But if you went with actives you could sell the amp to fund a preamp presumably. Unless you have a single source with avariable volume output, then you could hook it up straight to the actives.
Heng
Would a 2 metres side equilateral triangle sound similar in terms of soundstage to a 1 metre?
I do currently sit 1 metre away so it fulfils the correct position for this spacing
DT79
I’m not sure. Technically from a soundstage perspective it should be OK regardless of the distances involved, but it’s a question of scale. The bigger it is, the more it will sound like the real thing. Plus I think a lot of speakers come alive with a bit of power going through them, which you won’t really get the opportunity to do if you’re sat so close.
