Best speaker set for £400
davepuma
What AV Receiver or amplification are you going to drive them with? How big is the room? Any particular size/style?
There is a "what speakers should I buy" section in the speakers subforum by the way.
kam03
- Yamaha RX-V667
- No idea but but my current setup is 7.1 with the following distance to get an idea of the room size:
- Similar design and size of the speakers in the image below:
Thanks, will have a look there too.
davepuma
Q Acoustics 1000 or 2000 would be worth a look.
What about the Monitor Audio Bronze AV1 and adding something like the Wharfedale SW150 for £150. £50 over budget though.....
davepuma
If you go to the speakers forum and do a search a number of threads will turn up.
Your receiver deserves more than £400 worth of speakers but that's another story...:D
Trending threads
