Best Speaker package/separate speakers
Discussion in 'Home Cinema Speakers' started by rjcowan, May 3, 2001.
  1. rjcowan
    rjcowan
    May 3, 2001
    211
    Comber
    +5
    I am just starting to put a hopefully nice system together. Amp is the denon avr - 3801 but I am confused about which speakers to get for movie & music. Does anyone suggest a few options given a price range of £600 - £800. I am told that mission m70 series lack a bit at the lower level. :confused:
  2. Reiner
    Reiner
    Jul 16, 2000
    3,316
    61
    Germany
    +13
    Acoustic Energy 100 series or Mission Cinema7 should be a good start, add a subwoofer later for the last bit in low-end bang.
    [ 03-05-2001: Message edited by: Reiner ]
  3. sgecko
    sgecko
    B&W make great speakers although there a bit pricey. I use CDM2 stereos which are excellent but I'm not so sure about the CDMC centre....personally I think it's a bit too tinny but some say unless you start spending over £500 on a centre, you can't do much else. I use Tannoy R1s for rear centres which do the job and Tannoy M3s for surrounds. I think Tannoy are good value for money but you'll find you'll want to upgrade from them when you've got the cash. My M&K VII sub works wonders and it's small enough to hide between 2 armchairs. Good luck!!
  4. rjcowan
    rjcowan
    May 3, 2001
    211
    Comber
    +5
    Thanks lads I will take this into account and go and listen to them. Any good dvds i should try to show the quality of the speakers?
  5. Reiner
    Reiner
    Jul 16, 2000
    3,316
    61
    Germany
    +13
    I think the quality is better judged by using music, so take you favorite CDs along, too.
    And of course some DVDs you are familiar with, else 'The 5th Element' (rear effects, opera scene) comes to mind and perhaps 'Roy Orbison - Black and White Night' (multichannel music in DD and DTS 5.1).
    [ 04-05-2001: Message edited by: Reiner ]
  6. sgecko
    sgecko
    2 DVDs I definitely recommend to demonstrate superb sound are Ronin DD 5.1 (beginning and car chase sequence) and Gladiator (beginning scenes and battles) in DTS. My favourite is Saving Private Ryan in DTS....amazing!!! Good luck.
