Best Speaker Cable
Discussion in 'Cables & Switches' started by S2KI, Jan 13, 2003.
  1. S2KI
    S2KI
    Jan 3, 2003
    119
    London
    Can anyone help me out with some advice onspeaker cable. I have Kef 2005 sub/sat running off a denon 2802. I have been running crap gale cable until I finalised the install, which is now.
    I have a budget of £80 for 22m. Any advice is appreciated.
    Thanks.
  2. siluro
    siluro
    Jun 11, 2002
    443
    The Original "Garden City"
    Why not have a look at somthing like QED bronze special edition for the front and the micro for the rears. Both are pretty good cables and depending the actual indevidual lengths should fit into your budget with ease, £2.49 p/m and £1.50 p/m. The bronze special is basicly silver aniversary without the silver.
    cheers
    lee
  3. Silent Fly
    Silent Fly
    I have the same speakers :cool: connected to a Marantz SR5300.
    I use Maplin XR72P (£0.69/mt). It works quite well.
