WeaponX
Purchasing a new LG C1 65 inch, and looking to purchase a new audio set up as well. Currently use an Onkyo HDX22HDX, which I'm happy with, but it's starting to go off intermittently, so deciding to upgrade.
Some options I've looked at are:
Sonos Beam 2 with One SL Speaker set: https://www.sonos.com/en-gb/shop/surround-set-beam-one-sl-pair
I have a 15% discount code for the above, so it's about £680. Though the above has no sub with it. The Sonos sub costs the same amount again!
Polk Signa 4 - £320: Polk Audio Signa S4 (Black)
Denon DHT-S517 £378 - Denon DHT-S517 (Black)
Any recommendations on the above, other sound bars or even an amp / speaker set up instead (2.1 or 5.1) inside the budget instead is much appreciated.
Thanks.
Thanks.
