Question Best soundbar for my room.
Discussion in 'Soundbars, Soundplates & Soundbases' started by AlanT1, Oct 21, 2017.
Tags:
  1. AlanT1
    AlanT1
    Dec 14, 2007
    2,088
    63
    Bristol
    +134
    I have a small lounge about 16" x 11" with a staircase built in so not enclosed.
    My TV is at the end of the room and I mainly sit at the other end so about 14" away.
    I've had a separate system but with a wooden floor impossible to hide wires etc.
    Had a sonos play bar which was OK. Tried a Yamaha ysp2500 but didn't seem to suit my room style.
    Currently using a Panasonic sound base but won't to upgrade.
    My set up is lg oled and 4k player.
    Happy to but 2nd hand as my budget is only £500..
    Any advice would be much appreciated.
  2. rumbletumble
    rumbletumble
    Jan 5, 2008
    28
    3
    +5
    I bought the Philips Fidelio B5 and find it pretty good, I use it from about 12 feet away.
    I place the Sub behind the sofa, and the front side speakers can be split from the main unit and placed as wireless rear sides when needed, to give 5.1. When placed back into the main unit they recharge.
    I think I paid around 550 for mine.
