Best sound quality of 3 all in ones...
Discussion in 'Home Cinema Buying & Building' started by JimBob1971, Jan 12, 2004.
  1. JimBob1971
    JimBob1971
    Jan 12, 2004
    2,515
    +738
    Panasonic scdt310e
    Panasonic scht900
    Pioneer nsdv99
    I was considering buying a micro-system for my room to listen to music( the Denon M31), but noticed that Richer sounds were doing cheap home cinema kits. 310e for £299 nsdv99 for £369. Basically I was wondering which of the above have the best sound, both for home cinema, and just for listening to music.
    Thanks!
  2. hornydragon
    hornydragon
    Dec 19, 2001
    28,346
    +1,218
    SCHT-900 does avery good job of playing CD's at least as good as the £200 Stereo units from Sony and Panasonic add the fact that it is a 5 discer and plays DVD's etc and its a bargain!
    Havent heard the other 2 so cant comment best bet ids take a CD to Dixons or comet and listen to all 3.
  3. bonzobanana
    bonzobanana
    Aug 21, 2001
    3,449
    Yeovil
    +220
    The Pioneer will be best for music as long as you only play DVD Audio and SACD discs. I've no idea how they compare for audio cd playback. I think your just going to have to allocate the time and audition them.
    I suspect the Panasonic 310 would be best because its been optimised to playback 2 channel music well hence the two large main speakers. Thats how Panasonic promote it, as a decent hifi and home cinema system combined. Whether this makes it better than the other Panasonic or Pioneer model I don't know.
